  • Replies 72
well, if someone snuck into my carport and ripped it off... I guess it'd be for the best :(
I bet you would be hella upset if you had just fitted the Rear T wing with twin overhead c0cks as pictured here
I thought the c0ck-smoker was better.rofl
Yeah same here, I'm trying to stay on topic, and have some fun! The guys at j-spec and naked terror were rolling on the floor again when I showed them this thread today!! mind you it has gone down hill a bit :Oops:
I finally found it......
The black one wally has was the third one built by skylines australia. It was advertised on p7 of High Performance Imports mag issue 7 in 1999 for $65,000.00 with 'FAT33' numberplates. Very nice looking car.
