1992 s13 silvia non hicas
tuned at stz automotive northgate
rb25det and rb25det gearbox
1 piece tailshaft
new exeedy 5 puck clutch
garret gt35r.63 rear housing
greddy copy side plenum
gtr injectors
custom twin feed gtr fuel rail with option to run a extra injector
fuel pressure gauge in the rail for precise adjustment
turbosmart fuel pressure regulator
turbosmart 38mm ultra gate external wastegate
gtr intercooler
100mm throttle body
new yellow jacket coil packs
new plugs
new haltech e11v2
new haltech 3 bar map sensor
electronic boost controll with haltech
3 inch dump through to a 2 3/4 cat then into 3inch to the cannon at the rear cat still intact
5 stud front and rear
4 pot front and 2 pot rear brakes [r32]
shimmed r200 diff perfect never opens
set of dmax 17x8 front 17x9 rear wheels
set of standard r32 rims
aftermarket shocks with king springs
car has dent in front rh gaurd and small dent rh rear
car is fully mod plated and regesterable was my daily...
car makes 260hp on 6psi, 330hp at 14psi and 370hp at 17psi atw. i have the dyno graph from stz.
car will go over 400hp atw if you want to but 370 is safe and reliable as its my daily driver and 370hp in a s13 is a lot of power!!!!!!
will swap for a r32,s13 and 3-4 cash my way or $10000 ono cheap for cash as i need $$$$
ph 0437834932
post-38467-1265950783_thumb.jpgpost-38467-1265950798_thumb.jpgpost-38467-1265950806_thumb.jpgpost-38467-1265950815_thumb.jpgpost-38467-1265950822_thumb.jpgpost-38467-1265950831_thumb.jpgpost-38467-1265950842_thumb.jpgpost-38467-1265950854_thumb.jpg
https://www.sau.com.au/forums/topic/307960-s13-1992-370hp-atw-cheeeeeeeep/
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
