Hey,
Tonight i went out on a cruise and not long after it developed a clunking/metal-hitting-metal kind of noise after hitting big bumps but gradually got worse on the drive home, now most little bumps causes it to make the noise. The noise is coming from the front passenger side. Had a look and my left hand side tyre had a millimetre distance between the edge of the guard and the tyre (which is now back to its normal position). What i also noticed was the car was a bit sketchy to drive. Every time i would accelerate hard my steering wheel would loose it's 12'O clock position to more like 11:50-11:55 position to keep the car straight, so i figured everytime i accelerate some kind of force makes the left hand side wheel to move positions which causes the tyre to come in very close contact with the guard. Recently had a wheel alignment done at a Bridgestone branch.
Previous owner had set it up for handling and the occasional drifting. So it had consist of negative camber, toe, ect. The guy at the Bridgestone asked me if i wanted to retain those settings and i had said ofcourse. Although he did say he had set the toe back to straight apparently its bad or something.
Trying to rule out if it is the coilover that has shat it self or steering component related.
Any help would be appreciated!
Yeah i took the left side wheel off and had a suss..shaked a few things even the hub it self to see any movement but it seems it takes alot of force to move because it didnt move a single bit when i tried.
Taking it back to Bridgestone tomorrow..it seems that have fiddled with something and didn't do it right.
i had a knocking noise coming from one of my coilovers i though it was stuffed after removal, i found the problem was one of the nuts on the bottom of the thread where u wind them up and down was a bit loose and it allowed the spacer over the threaded part to rattle up and down slightly under load, just tightened it up and it should be all fine now. but my wheels didnt move side to side sounds like a rear cradle issue or something if your wheels are moving side to side and out towards the gaurds.
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
