ive never felt a 2835, but a t04 on a soarer at 1 bar boost makes the thing hammer, est rwkw about 230rwkws on the soarer
the one ive bought is a fully rebuilt one with a bigger wheel for $900
they r pretty cheap turbo if u know where to get them
https://www.sau.com.au/forums/topic/30833-hks-t04/#findComment-623152
Forgive me if I'm a bit confused but the way HKS works is the 2000 series, the 3000 series, then the T04, then the T51 series.
ie. the 2835 is the largest of the 2000, the 3037/3040 is the ext. wastegate models and then it's the T04.
So...
Isn't the T04 incredibly large for the RB20/25 series?
T.
https://www.sau.com.au/forums/topic/30833-hks-t04/#findComment-623371
There are four different types of HKS T04. Most of them also come in with different diameter housings as well.
I think it goes- T04s, T04r, T04r Cut Back, then the new kid on the block the T04Z. Apparently the T04Z is set to revolutionise turbos with its unique impeller design. It has holes drilled into the excess metal, feeding air into the edges of the impeller. Apparently this is said to prevent surgning with the larger impeller.
With the link, on the righthand side under 'new releases' click T04Z
http://www.hks-power.co.jp
This concept is similar to the new Trust T88H-38GK
https://www.sau.com.au/forums/topic/30833-hks-t04/#findComment-623902
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
