Year: 1991
Model: Si-Vtec
Trans: Manual (rare in JDMs apparently)
ODO: 180,000
Colour: r81 milano red
Interior: black/dark grey
Reg exp: october 2010
factory Items:
- JDM Black one piece headlights
- JDM Climate control
- JDM Electric folding mirrors
- JDM Rear wiper
Audio
- new pioneer cd/mp3/usb head unit
- Front - JBL 6" Splits
- Rear - Latest Fusion RE-CM650 6.5" splits
Engine/performance
- X-Force 4-2-1 Headers
- X-Force Downpipe
- X-Force Hi-Flow Metal Cat
- X-Force Twin Tip Muffler
- Limited Slip Diff
- Class "B" Clutch Kit
- AEM Short Ram Intake
Suspension/handling
- Rear Generic Strut Bar
- KYB Shocks
- kings Low Springs
Car had a major service done around 2 months ago now, including :
- New hydraulic/auto tensioner from honda
- New timing belt
- New water pump
- New crank seal
- New sump seal
- Engine flush
- Radiator flush
- New oil & filter
Chasing $8000 negotiable.
my friends skyline pulled 128.4kw max on dyno last week and when we had a little boot , i pulled away quite easily, havent had the car dyno'd but thats just to give a rough idea. and no the car is not thrashed. have taken very good care of this car in the past 2 years i have owned, runs excellent!
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
