hey have some interiour stuff for sale as im stripping it for track
rear seat $5o
rear trims $50 for both
rear seat belts $60 the lot
passanger seat belt $30
console around gear shift, with lighter spot cut out to fit boost gauge $40
centre consol back from gear stick $35
glove box $30
side front kick panels with tweeter holes $30 for both.
gfb blow off valve with rb25 adaptor $100
hi mount polished t3 manifold $200 with 48mm gate welds rough on inside.
any other interiour parts let me know might have it too.
all parts ono. cheers
https://www.sau.com.au/forums/topic/309126-r33-parts-for-sale/
  • 1 month later...
Do u have pics of door trim? Is it a r33 s2??? Also pics of gear shift pieces.... Very interested In. These items!!!!
Please pm me where your located an pics too please! Thanks!
sorry for late reply, its s1 trim mate can get pics and pic of gear shift pieces too if still interested
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
