So, long story short - car has been scratched because of a garage issue. Wont go into it as im still upset..
anyway, the paint is gone, and the scratch is too long and wide for that stupid pen. Will have to get it fixed eventually, but is there any stuff i can buy like those magic pens except easier to apply with a paint brush? Will need to protect it from rust.
https://www.sau.com.au/forums/topic/309319-deep-scratch/
They're double sided pens with my exact paint color code. so for stone chips etc you just apply with the pen and on the other side is a clear coating to seal it. Its only good for little chips we all get on our front bumper really.
Ogz, im in brisbane but looked up the touchupguys here and they seem legit. Will take before and after pics for anyone whose interested in brisbane.
https://www.sau.com.au/forums/topic/309319-deep-scratch/#findComment-5101269
Anybody out there that wants a job done as good as a panel shop but a hell of alot cheaper try these guys, And not just for scratches they will even fix small dents and few other mishaps , alloy wheels etc. All in the comfort of your drive way.
http://www.thesmartguys.com.au/
Not a franchise so go the National Pricing.
https://www.sau.com.au/forums/topic/309319-deep-scratch/#findComment-5102127
there is now new restrictions in terms of shipping this from overseas.. Due to its liquid substance majority of the dealers there do not choose to sell this to overseas customers, however you can always try. I tried before and failed, so i just went to local nissan dealer parts and got mine for $15.00.
https://www.sau.com.au/forums/topic/309319-deep-scratch/#findComment-5111969
went to nissan today they have it, its a nail polish sorta thing and you apparantly apply it, the guy there didnt know anything about it, so im wondering do you need to prep the car or do anything before applying it? also does it blend with the colour and surrounding or would it stick out like a sore thumb?
https://www.sau.com.au/forums/topic/309319-deep-scratch/#findComment-5112600
Ive used the same from g35parts, IMHO they are ok for very small areas, anything other than that you`re better off getting it done either at a bodyshop (dependant on extent of damage) or by some touch up franchise (do your research first as Ive seen some appalling work)
My bodyshop does stuff like full bumper respray etc and I use chipsaway (local franchise) for any light scratching/stone chips elsewhere.
Good luck in getting your 350 sorted
S
https://www.sau.com.au/forums/topic/309319-deep-scratch/#findComment-5113380
Hey sai how much does it usually cost ya to do those scratches and stone chips?
S
https://www.sau.com.au/forums/topic/309319-deep-scratch/#findComment-5114134
    • If your tuner can't make the car idle like factory, I'd get a new tuner. These injectors are fantastic and I'd have very serious concerns about a tuners skill set if they couldn't get them to idle well.
    • It's highly likely you will find something. Alternatively, a quick design and order online from chaina and you'll have a perfect solution
    • Idle Lambda target is off by .4 but I reckon the VE table is not correct. If my tuner has no issue using these injectors I will keep them, they are good quality after all
    • I already have an Apexi. Just wondering if it is worth putting in something new since the Apexi is likely well over 10 years old, if not 15. I know the injectors work but they already run at less than rated fuel pressure to make them work properly and idle is basically 1% duty cycle or less. Could be better
    • Nice, I would never have thought in that direction. The actual motor is a cylinder....I wonder if there are any cylindrical heat sinks with the right ID  (and if there is clearance to other components). I think adding airflow is still a thing as well....will check it all out next time it is in the air. Wish I had a hoist...
