For sale 92 r32 gts-t
30,000ks on engine before rebuild and 122,000ks on chassis
white with black boot and bonnet
white enkie racing wheels,
fresh rb20
5 speed manual triple plate brass button clutch
nismo 2-way diff
g reddy front mount
$9000 ono. very negotiable on price quick sale needed
if interested contact Josh on 0400913465 cheers
cars located in brisbane
https://www.sau.com.au/forums/topic/310204-for-sale/
