hey guys, when ur talkin about the sway bars is it the bars underneith the car or is it the one in the engine(strut??) anyways im lookin at pickin one up (whiteline adj for 190) and would like to know which of the two would be better to upgrade, the one under the car or in the enginebay and the front or the rear. im guessing the fronts as its rwd.
as for the aftermarket hicas bar...rezz as a "Attain - HICAS Cancel Rod" goin for $166 bucks accordin to the calculator...hehe. dunno if it comes with the electronic bypass thingy for the 33 though.
Go for the swaybar (under the car) first if you want less body roll. the strut brace won't make much different for body roll, it will only increase chasis rigidity for high speed cornering, but most of the time during general driving you won't feel the difference with or without the strut brace.
Better to upgrade both front & rear swaybars, it will allow u to tune understeer & oversteer characteristic of your car. In theory if u have stiffer rear swaybar and softer front (or the other way around), ur chasis could twist during hard cornering because of different body roll front & rear... I would imagine it wouldn't be too nice
No worries Sydneykid. The JMS one for $195 isn't listed as being suited for R33's. I found that K's Online Garage (as (B1) MR_fanny mentioned) has the cheapest at $166 + postage. Gotta find out from Rezz if SAU members get a discount.
thanks rs73....i was thinkin of the front whiteline adjustables and the rear "dori dori" swaybar on K'sgarage. what do u guys think of this combo?? come to think of it if i get the whiteline rear adj then all i need to do is set it stiffest when needed??....hmmm also is it fairly easy to adjust the swaybars?? would i need a hoist? and does it put my wheels out of alignment everytime u adjust it??
Hi B1, to adjust the stabiliser bars I jack up the rear of the car (under the diff) and remove the wheels. Undo 1 bolt each side on the stabiliser bar adjuster. Move the link the number of holes you want, and replace the bolt. Simple, hardest part is jacking the car up.
Adjusting stabiliser bars has nothing to do with wheel alignment. So no, you don't have to get it aligned every time you adjust the bars.
Hope that helps
  • 1 month later...
It looks good!!
I didn't put it on myself, Centerline Suspension in Thomastown did it for me, but from your pics it looks right.
The adjustible caster rod bush on the front does come in the bushes only. You still use your standard caster rod arm.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
