when i got my s13 silvia change over to an extreme organic heavy duty clutch labour was 350 with flywheel machining and i paid 400 bucks for the clutch from autobarn which i later realised was a real dumb idea. unless skylines are harder which i find hard to believe then it shouldnt be more than 700 all up
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
