Hi,
As the title suggests I urgently require some R34 GT-T stock top hats. I am taking my coilovers out and going back to a bilstein and whiteline combo. I need the stock top hats as it came out from japan with coilovers in it.
I really need the rears asap. Going to get a quote for some new ones from nissan but i am tipping it is going to hurt. Help me out!
Jeff 0400648813
Ok all the research i have done suggests the only differences between R33 and R34 suspension is the bottom of the shock whether they are forks or balls. Obviously this has nothing to do with the top hats.
Lower part of shock:
- balls at the front and forks at the rear. R33GTR and R34 GTT
- balls at the front and balls at the rear. R34 N/A and R33 GTST
Do they look like this?
http://www.skylinesaustralia.com/forums/post-a47513-
But yeah it would be good to get confirmation for sure
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
