have two cars at the moment which i am unable to afford to keep both.
This is an Expression of Interest ad for my S13.
Details:
Motor / Exhaust:
- 1993 Year Model
- Chassis/Body has 230xxx kms
- New Engine and Transmission installed by previous owner
- 1994 Silver Top SR20DE Engine (60xxxkms)
- Automatic Transmission (55xxxkms)
- 3" Inch Exhaust System to a 4" Exhaust Tip (beautiful note)
- ASI Dual Core Radiator only 6 months old
- PWR Oil Cooler 6 months old
RIMS / SUSPENSION:
- OSAKA RS5 18Inch Rims (No marks, scratches or gutter rash)
- Front Tyres are Nexen N3000 225/40/R18
- Rear Tyres are Falken ZE329 Tubeless 235/40/R18
- Car gets low thanks to King Springs Ultra low springs all round.
EXTERIOR / INTERIOR:
- Front Light conversion from Brick style to projector style
- Aftermarket Clear Side indicators
- Aftermarket Tail Lights
- Tinted Windows
- Fully Painted body kit
- Fully Painted Interior inc Dash, door trims etc (a few scratches in paint work which can easily fixed)
- New SASS Racing Steering Wheel
- Matching Seat Covers
- Agilon Alarm / Immobiliser with Remote start and 2 remotes. Remotes work up to 1.5kms away and scares and intrigues people when it starts by itself.
- Central Locking
- Extra Drive lights mounted on Front Bar
- Car fully rebadged with Transformers Decepticon badges.
- Transformers Racing Pedals can also be included in sale of car.<br style="">
Car runs well and will be sold unregistered.
I havent registered it, since i bought it, so all that will be provided is Transfer papers.
Putting the price at $6500 but i am open to offers.
I am getting a rego inspection (TBC: 22nd-27th March) done to see what needs fixing in order to get a road worthy cert.
Contact: 0423 303 742
Postage can be organized into another state.
https://www.sau.com.au/forums/topic/311655-eoi-1993-nissan-silvia-s13-sr20de/
price drop to $4,000 without RWC.
In order to pass road worthy, it needs the following:
- LEFT HAND TIE ROD
- RIGHT HAND RACK BOOT SPLIT
- RIGHT HAND FRONT TYRE WORN
- RADIUS ROD BUSHINGS SPLIT
- EXHAUST LEAKS
- LEFT HAND REAR TYPE DAMAGE TO SIDE WALL
- LEFT HAND BRAKE LINE INSECURE
Quoted approximately $1,4500 to fix + obtain a rwc at Belconnen Exhaust & Automotive.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
