R34 gt silver sedan, RB25de neo, came from japan auto so i changed it to manual, the car has done 135,000kms and the clutch and box and tail shaft have done 55,000kms! over all the car is in good condition! Runs like a dream! Very hard to find the n/a 4door in manual! It really is a great p plate car!
Reg till Feb 2011, comes with rwc, car is very good on petrol, gets 450-500km's a tank.
what i have done...
front summit strut bar
front and rear redline sway bars
hks coilovers(one needs rebuilding)
2 1/2 inch all the way though(comes with stock one)
high flow cat
cannon muffler
custom made extractors
GTT turbo diff
r32 gtr wheels(comes with stockies)
3A racing pod filter
dvd head unit(comes with stock head unit)
8 inch sub and amp!
brand new splitfire coilpacks
brand new o2 sensor
drift gear knob
eye lids
manual conversion
still has the auto steering wheel on! but i have a nardi that ill chuck in, it comes with boss kit!
its had its 100,000kms service all belts and fluids everything done! Just had new premium spark plugs put in at last service! car is serviced every 8000 to 10000 kms being n/a! reason for selling.... need $$$$
looking for about $11 500 neg! im in vic, hallam! pm me or give me a buzz on 0433 467 819
https://www.sau.com.au/forums/topic/311980-r34-gt-4door-na/
If only i had the Zed sold this would be instantly what im after.
Can you please send me some more pictures to, [email protected]
And if able, take a pic of the interior, seats, space. That type of thing.
I unfortunately dont know anyone with a 34 so to test drive and take a feeling of the car.
Might see what i can make happen. Have to show the missus some more.
Cheers,
Chris.
EDIT, do you have any of the original air intake items. As a noticeable POD wont get passed here in SA.
Also how loud is it now with the new exhaust system? I see the stock unit is available.
To your knowledge how much is it to 'fix' the shock? Ball park figure.
Any further info, odd sounds, things that may be picked up from getting it passed.
Thanks again.
Edited by Sanouske
https://www.sau.com.au/forums/topic/311980-r34-gt-4door-na/#findComment-5182242
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
