Hey guys,
I did a quick search but couldnt realy find an answer.
My Question is , How strict are the pits/ cops on the wide body FRP front guards?. Do I actaully have a chance of getting my car registered with FRP front fenders. (I also have a frp bonnet but im going to bond the metal support from a stock on to it).
My mate kindly informed me that because im removing a crumple zone item (metal guards) and replacing with Fiberglass ones, this is defect worthy =(. But apparently the rear wide fenders are ok, if they are bonded over stock items.
Any info / suggestions / help would be great guys
https://www.sau.com.au/forums/topic/312008-frp-guards/
quick answer - very
long answer - if the guards in question have been manufactured by someone who has already had them proved to conform to ADR 69, 72 and 73, and provide documentation as such, the only thing you will need to worry about at the pits is wether they have been mounted correctly. If the guards cannot be certified then IMO dont even bother. The structural and hardness testing to prove they will conform will destroy at least one set of guards, and set you back a few grand to get done anyway. I dont have a copy of the vehicle modification guidlines with me atm, but if you have a look on the dop website, check out the modification guide for street rods, as it covers all the requirements for FRP for both full body and bolt on guards
*rummage*
http://www.transport.wa.gov.au/mediaFiles/lic_cp-105b.pdf
section 5
*edit - Bard, its got nothing to do with being structural, its all about frontal impact protection for ocupants and pedestrians
https://www.sau.com.au/forums/topic/312008-frp-guards/#findComment-5134243
You sound like you know what your talking about.....otherwise thats some awesome bullshit you just spun lol
But seriously, that sounds very true and i do not doubt you for 1 minute.
https://www.sau.com.au/forums/topic/312008-frp-guards/#findComment-5134279
Thanks for the link guys
The way Im reading it, its differentiating between non intrusion and structural.
The testing appears to be limited to structural items, from the way im reading it.
So going from that , the only stipulation for bonnets is that they are 3.5mm thick and use stock mounting… ?
https://www.sau.com.au/forums/topic/312008-frp-guards/#findComment-5134302
The way I read that is: guards and bonnets are not required to be tested/certified, they must be at least 3.5mm thick (without gelcoat) and utilise stock mounting locations with a neoprene, then steel washer at least 20mm in diameter.
https://www.sau.com.au/forums/topic/312008-frp-guards/#findComment-5134569
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
