Turbo kit back up for sale due to timewaster. If you're not ready to purchase then please do not contact me.
HKS T300 Turbo kit including:
HKS T300 Turbo: .6a/r, 3" inlet, 0.63a/r exhaust housing, excellent condition.
HKS modified stainless low mount manifold - professionally modified by a boiler maker to ensure no cracking and relocated the external wastegate to a more serviceable area. The kit is not 10 times easier to work on.
HKS 40mm External wastegate
Custom inlet pipe
This has made 285rwkw's on my SR 2.2 at 20psi with a quick tune and a boost leak from the injectors so more in it.
All modifications just completed.
Price: $2000
For anyone who wants to hear what it sounds like (mic level was turned up a bit too high on the track vid):
Dyno:
PM or reply here
Located in Melbourne but can ship at buyers expense.
Dane
https://www.sau.com.au/forums/topic/312282-hks-t300-turbo-kit-sr20det-sr20/
    • Ironically the GTT was quite reliable in the 7 years of ownership. From memory I've only had to replace a radiator and coilpacks out of inconvenience
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
