Fs: Used Exedy Nc10t Pressure Plate For Push Gt-r Or Gts-t // Machined (matte) Rb25det Flywheel // R33 Gts-t Or R32 Gt-r Push Slave Cylinder
Hi Guys!
Recently replaced my clutch kit so these parts are for sale!
Item: R33 1998 GTS-t Slave Cylinder
Condition: Good Condition, No Leaks, No Cracks on Leather Boot, 101k kms
Price: $40
Item: Exedy (NC10T) Pressure Plate from R32 GT-R Push Type Sports Ceramic Clutch (Silver One/Made in Japan/Not that Pink Shet :blink: )
Condition: Used, some very slight heat stress marks, came off my GTS-t.
  • Suits NSK-7121SO or NSK-7121SC
  • Pressure Plate Clamp Rating: 10,800N/1,101kgf,2,482lbf
  • Casting Type: Ductile (Anti-Burst) Cast Iron
  • Great for rebuilds!
  • Send it to Jim Berry
Price: $100
Item: R33 1998 GTS-t Stock Fly Wheel
Condition: Will Supply Machined with matte finish as recommended by Exedy
Price: $100 (Machined) $50 (As-Is, still very flat with no scores)
PICK-UP ONLY (Except Slave, will post for $8.95)
Contacts: PM or Here!
Cheers,
Johnny
Clutch Slave SOLD
Available:
Exedy Pressure Plate
RB25DET Flywheel
RB25DET Pivot Point, will fit R32 GT-R Pre 1993
Still for Sale! - Take the Lot for $120
** Exedy NC-10T Pressure Plate
** Factory Pivot
** Factory Flywheel un-machined
  • 4 weeks later...
  • 3 weeks later...
TAKE THE LOT REMAINING FOR $100
** Fly wheel
** NC10T Pressure Plate
** Stock Pivot
** Fly wheel
** Stock Pivot
Is it still for sale ?
Could you put pics about pressure plate ? Can i fit it on my r32 gtr 1991 ?
regards
regards
Hi there,
I will take photos of it on the weekend... Provided your R32 GT-R uses a 'Push-Type' clutch setup, then yes. I believe all R32 GT-R Pre March 1993 uses Push. Please check.
Hi there,
yes it's push type.... is it in good condition ? could i make paypal transfer ? could you send me it ?
  • 1 month later...
  • 2 months later...
    • UPDATE: Yes the GSP Axles are compatible. I installed it on my R34 today and they are working a treat! Turns out that the S13, S14, S15, and 200 SX all used the same axles as the HR34, and ER34 NA models. Which is 2 bolt x 3 pairs.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
