Item: Wolf 3D V4 (V400) with Hand Controller
Condition: good condition, no scratches on computer, slight mark on No3 button on controller(really nothing)
Price: $800
To Fit: R33 GTS-T and R32 GTS-T
I am selling a wolf 3D v4 rev 7. This is a plug in and play unit with hand contrller and cable and software for laptop. It is stickered Nissan R33 and as wanted it for my Rb20 I contacted wolf and was told it does both. tuned on the rb 20 on it with 520 injectors and gt35 turbo (yeah was ridiculously laggy hence whole new set up)
Some details on the Wolf unit (collected from other posts):
The Wolf 3D Version 4 is fully 3D tunable for both fuel and ignition timing!
These ECU's are an excellent unit with incredible tuning resolution, both ignition and fuel can be adjusted every 125rpm with 16 different load bands. This compares very well compared to Microtech that can only be changed every 500rpm with less load points. Having such a fine tuning resolution is perfect for getting the most out of your modified engine.
No need for a Z32 AFM with this ECU, simply remove your AFM all together.
Overall this ECU provides sharp, crisp throttle response whilst still maintaining factory drivability e.g smooth idle, fuel economy, cold start etc, something impossible with many of the competitors ECUs.
Some of the benefits of fitting a Wolf 3D V4:
Make the most out of your modifications
Excellent drivability, Wolf 3D V4 features full cold start and air temperature adjustments
Easily retuned if you change a modification
Crisp and smooth idle
Excellent fuel economy
Ability to remove AFM. ECU is MAP sensor based so no need for a Z32 or the airflow restriction a AFM causes
Boost controller can operate with factory solenoid
Can run multiple Maps with live map switching while the engine is running(Power Map, Economy Map, or Low Octane fuel)
Specs:
Tune from PC Software
Maximum Engine Speed 20,000RPM
Fuel Map every 125RPM to 16,000RPM
Fuel Map has 16 Load Bands
Ignition Map every 125RPM to 16,000RPM
Ignition Map has 16 Load Bands
Idle Speed Control with Water Temperature Compensation
Sequential Fuel Injection
(these details were pinched from a thread by skysaresilver)
Will try and post pics this afternoon.
Can post goods are buyers expense.
https://www.sau.com.au/forums/topic/312681-wolf-3d-version-4/
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
