I just want to know 17x7JJ, 5x114.3 PCD and possibly a +42 offset from m35 rim and tyres are 215/55/17 will fit in my S2 or not.
Thank you
I think they'll end up too far inside your guards with that offset, won't look very nice, I'd look for something with an offset of at least +30 and around 8" wide.
they will fit but wont look too good. my car came over from japan with 17 x 7" rim and around a +45 offset. tire was a 225 50 R17 and i had no trouble with the tire hitting the strut so a 215 will be fine. the fronts sat in the front guard by a mile lol. the rears where better but still sat in a little.
so to answer your question, yes it will fit. but if you have a choice hold off for a rim with a better offset. i'm now running a +30 offset rim and they sit in the front guards ok, rears sit perfect once lowered. car is a auto S2.
Just yesterday I fit 19x8s on the front wearing 235/35 with no dramas at all
19x9.5s fleshed the back sporting 245x35s.
Wouldnt fit with standard springs but the coilovers allowed for them (just, I put on an 8mm spacer to stop the rubber skimming the strut on corners, and only because I couldnt source a 5mm spacer)
Steam rollin!
With a lip roll on the back there will allow enough clearance to slam it down another 20mm (stock ride height atm)
Steam rollin!
You might have problem with different rolling diameters front to rear. . . .
rolling diameter should be the same?
Just widths are different... proving a smooth ride so far..
sorry mate but the rolling diameter will be different. having a 35 profile tyre means that the side wall is 35% of the width, therefore if you have a wider tyre, the sidewall height increases in proportion with the width increase. 235/35 = 82.25mm sidewall. 245/35 = 85.72mm sidewall. which means you have a 7mm difference in tyre height. this may be enough to cause trouble.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
