Hi guys, on the R32 GTST circuit race car we run 400 lbs per inch (7.25 kg/mm) front springs and 250 lbs per inch (4.5kg/mm) rear springs. That's on very smooth race tracks in the dry, on rough tracks or in the wet, we run up to 20% less than that.
The job of the spring is to hold the car up, absorb the compression loads and allow extension to make the tyre follow the road surface. Too high a spring rate lessons the tyre's contact with the road. It is not the job of the spring do other things, like limit the roll, that's the job of the anti roll bars. Likewise, it is not the job of the spring to limit the front end dive under brakes or the rear end squat under acceleration, that's a job for the anti dive and anti squat suspension geometry.
That's the main reason why I personally am not all that keen on Japanese suspension kits. They try to do everything with the spring and damper rates. They do that to such an extent, that I can't even use their road suspension on the circuit.
Hope that helps
https://www.sau.com.au/forums/topic/31310-cusco-comp-s/#findComment-632364
Cheers Sydneykid, it's all good :(
so what would you reckon would be the best rates for road use, I don't mind a bit of firmness but the way it is now it's going to wreck the rest of the suspension. Maybe 270-300lbs for the front and 170-190lbs for the back? you probably have much better anti-roll set-up than me ( i assume mine is still standard ) so I may need a strong enough spring anyway? am i even making sense???
https://www.sau.com.au/forums/topic/31310-cusco-comp-s/#findComment-632454
  • 1 month later...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
