And haven't seen an 105E Anglia for years. I used to race against them with 289 V8's in them at Warwick Farm. Was this car V8 powered?
Hi Dennis,
No it's not a V8. Here's a better pic:
Nice rims!
JH
  • Replies 49
Posted Images
Don't have a scanner working at present, but maybe these pics will suffice.
D
My Car looks very differnt under the bonnet to the car in that pic. That engine bay shot, is of the 85-86 cars.
Even tho the program is from 1987, that doesn't mean the pic is. My air box, radiator and a heap of other stuff is different. My car also had more power for 1987, 276kw versus 246 in 1986. Mine does not have a rear stabiliser bar either.
Mine was the only one set up for radials, so maybe this is why the roll cage is so different, no strut brace, and no rear stabiliser.
My car had been rebuilt also before it was retired. Everything in it is new, including shocks, springs etc.
Where's the happy snaps then!! Would love to see that engine bay! What car was featured in zoom? Was that Gavin's?
I just watched the videos of it at phiilip island and it looks like a bit of a handful! Is that a bad ignition breakdown down the main straight?
No it's on the limiter with 411 gearset, needs 3.7's at Phillip Island.
No, that car is mine, when it belonged to Terry Ashwood, it was taken out of the restaurant for that feature.
Pics of my engine bay.
Straight after the fire in teh engine bay.
Cazz,
Do you know what spring rates are in the back of your #30 car?
No idea Ghostrider, but it needs some better ones. When the car is on the air jacks and warming up, the movement in the rear is unreal.
  • 4 weeks later...
    • If your head gasket lifted, you should have seen a coolant pressure spike. There's no need for a copper gasket/fire rings at 30psi. An MLS with perfectly clean/flat mating surfaces should suffice.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
