hi everyone im selling a few parts of my written of r33 located in Melbourne call or text if interested 0423 967 556
Rack pinion $150
master cylinder and booster $150
Hubs x4 $600
dba 4000 series slotted rotors x4 $450
red callipers with pads x4 $500
auto with shifter and computer $500
diff $350
3.5" stainless steel exhaust still available from turbo back $600
mag wheels still available x4 90% thread 235/40z/r18 $700
set of stock r33 wheels 2 tires not bad other 2 need changing $200
Rear strut brace $150
there's more bits and pieces this is just the main stuff i need out of the way
https://www.sau.com.au/forums/topic/313895-r33-s2-parts-and-running-gear/
  • 3 weeks later...
yea man diff is still here nah its in very good condition no hums and only done 120368kms and coming off a auto its till pretty tight call me if ur interested 0423-967-556 or 0432-062-780
steering rack sold this is still available
Hubs x4 $500
dba 4000 series slotted rotors x4 $400
red callipers with pads x4 $400
diff $350
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
