FOR SALE my MY01 WRX HATCH, now up for sale due to money owed. Much regretable sale.
It is an incredible car to drive and never misses a beat.
Never had a single issue with the motor at all.
Condition: Used
Reason for Selling: Need money for loans
Asking Price: 17500
Delivery Methods: PickUp
Contact Info: 0419269983 or PM me.
EXTERIOR
* Excellent paint and straight body
* Koya 18" Wheels with good tred
* STI bonnet scoop
* Black bonnet
* Lowered King Springs
* Custom Chrome Mirrors
INTERIOR
* WRX seat covers
* 6-stack CD player
* Blitz Dual spec SBC spec-r Electronic Boost Controller (Programable 4 stage)
* Blitz Boost guage (Pilar Mounted)
* Greddy full-auto turbo timer
MOTOR
* EJ20t 120000km
* Front Mount Intercooler (chrome piping)
* Turbo-Smart Blow Off Valve
* Turbo back 3" exhaust with 5" cannon (sounds sic)
DRIVTRAIN
* New front Rotors
* Just replaced Gearbox and Diff to a 4.44 ratio combo (much better accelleration) cost me around $3200
* Fully replaced Viscous centre to mechanical type, mid housing and all new bearings and seales throughout Gearbox
Overall the car is in immaculate condition and will not disapoint.
First to see and drive will buy. It is very reliable.
--- $17,500 ONO ---
* Would prefer cash but may trade + cash my way.
Please call me or PM me if you have any questions.
PH. 0419269983
Located near Lismore northern NSW
Also i have extras if wanted, including;
-2000 model EJ20t (low compression in cylender 2) great for parts
-3.9 ratio diff
-old rotors
Photos: PLZ click on the following link to c pics...
http://www.boostcruising.com/forums/index....entry1285414773
Thanks for your time.
https://www.sau.com.au/forums/topic/314108-my01-subaru-wrx-hatch-back/
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
