FOR SALE: NISSAN S15 200SX 2 DOOR COUPE SILVER
BODY - IMPORT REAR BAR,DELETED REAR WING,REMOVED BADGES,SMOKE REAR TAIL LIGHTS,TINTED WINDOWS
OPTIONS- POWER STEERING,POWER WINDOWS,POWER MIRRORS,WHITE FACE GAUGES, A/C,SPORTY TRIM & SEATS,ALARM
ENGINE - SR20DET,POD FILTER, HKS BOV, FRONT MOUNT INTERCOOLER, BOOST CONTROLER, NISMO RADIATOR CAP
GEARBOX - 5 SPEED S14 CONVERSION ( GEARBOX STRONGER ) NEW EXTREAM SPRUNG BUTTON CLUTCH
EXHAUST - 3 INCH TURBO BACK + REAR TURBO MUFFLER ( GREAT SOUND )
SUSPENSION - TEIN FRONT + REAR COILOVERS, CUSCO ADJUSTABLE CASTER RODS, FRONT STRUT BRACE, NISMO REAR TOWER BRACE
WHEELS - NISSAN 350Z 17INCH ALLOY WHEELS
DIFF - 4.1 RATIO 2-WAY MECHANICAL LSD
INTERIOR - BLITZ BOOST GAUGE, S14 GEARKNOB,TURBO TIMER
SOUND SYSTEM - SONY CD PLAYER ( DVD PLAYER IN PICS NOT INCLUDED )
SERVICE - ENGINE OIL GET CHANGED EVERY 2000KMS,JUST CHANGED GEARBOX + DIFF OIL
OVERALL - NICE LOOKING CAR WITH GREAT POWER AND HANDLING ,GOOD ON FUEL
REFER OLD EBAY ADD FOR PICTURES - CLICK THE LINK BELOW....
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...e=STRK:MESOX:IT
PRICE $15,000 AS IS OR
$16,500 FOR THE PIMP PACK WHICH INCLUDES:
19INCH WHEELS + DVD PLAYER + G-SMART METER + STREET LOWERED SUSPENSION ( WILL INCLUDE TEIN COIL OVERS ) AND DILDO GEARKNOB
PIC SHOWS CAR WITH LOWERED SUSPENSION AND 19'S
ALL INSPECTIONS WELCOME FROM OAKDALE NSW 2570 CALL 0409909405
where are you located? and do you have a service history and log books?
located at Oakdale nsw 2570
no service history, I'm a mechanic and do all my own service work
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
