Hey,
I'm putting my Tein CS coilovers for sale as they don't fit my manual S2 RS Four S. I haven't used them & they will arrive this week from Import Monster.
This is the roughly translated description from Import Monster:
Nissan Stagea (WGNC34) is an exhibition of CS type for the Tein. Been overhauled by the manufacturer. In that case, cutting short stroke (Ft-mm 10, Rr-35 mm), replace the piston rod, piston valve replacement, and I have a dust seal replacement. Spring rate of spring are now teamed Ft7.0k, Rr6.0k it. After OH distance is about 5,000 kilometers.
They come with the manual for the coilovers, as well as some stickers. I am not sure if they come with the Tein spanner to adjust the height. I will confirm that once they are delivered to me.
I am selling them for $1000.00.
I am located in Enoggera QLD, pickup is preferred. I can deliver in Brisbane or the Gold Coast in the next week. Freight for people interstate is up to you to organise.
Any questions, please drop me a PM.
Cheers,
Adam
https://www.sau.com.au/forums/topic/314979-tein-cs-coilovers-for-sale-1000/
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
