sorry don't know how to edit other thread.
So now engine and gearbox is gone, i'm stripping rest of the car.
Car is a 95' series 1.5 r33 gtst, silver in colour. No quarter panels, front or rear bar as bodykit is completely moulded on :cool:
Items are located in Dandenong victoria, still in vehicle so will need time to remove.
will post at buyers expense for easily posted items. pick up for larger
EXTERIOR & ENGINE BAY
Item: Boot with series 2 spoiler and light in charcoal grey
Condition: no badge, slightly scratched
Price: $80
Item: Mirrors
Condition: fine
Price: $100
Item: Washer bottle
Condition: great
Price: $20
Item: Radiator w/ shroud
Condition: No leaks, rusty water ran through as had leaking water pump
Price: $40
Item: Pink label AFM
Condition: Working perfect, 1 broken mounting braket hole
Price: $80
Item: Airbox and snorkel
Condition: perfect, with 1 week old k&n panel filter
Price: $100
Item: Full 3in turbo back exhaust, 2 1/2in cat, 3 inch muffler w/ 5in tip
Condition: great, sounds tough too
Price: $900
Also have front and back windows (make an offer), Doors with windows and window reg complete.
Also have headlights and bonnet but maybe sold, so will keep you informed.
INTERIOR
Item: back seat complete
Condition: slight fade from sun, no tears whatsoever
Price: $80
Item: Front seats complete
Condition: no tears or fades whatsoever
Price: $200
Item: door trims driver and passenger complete
Condition: great
Price: $100
Item: dash faschia? the bit that goes roung the streo and over steering column
Condition: been sprayed mat black from a can, no damage
Price: $30
Item: climate control unit
Condition: perfect
Price: $60
Item: seat belts, complete set w/ bolts
Condition: perfect
Price: $80
Also have dash cluster reading 138,000k's, make an offer
No pics at the moment but can if necessary.
Contact : Brad 0422056446
Pm, SMS, or phone call
All in Dandy? I mite come have a look on the weekend if thats ok. I'm chasing a few things for my series 1.5. PM me your number if thats cool
Just read you number. My bad still half asleep. I'll give ya a call
Edited by adzr33
no worries mate. when ever your ready
Climate control unit solddddd
Parts added
Roof lining: $10 (1 or2 dirt mark,easyto get off)
Roof lights: $20 both (both fine)
Back seat side trims: $50 both (perfect condition)
Parcel shelf: $10
R33 s1 bonnet: $150 with water jet and heat shield,no dints
R33 s1 passenger headlight: $70, slight yellowing but structually perfect
R33 boot with veilside: $180, not much usage as it wasn't to my taste
if any one comesto pick these items up and pays liste price i'll install it on the spot for you.
not that much of it is hard haha
how much you want for the washer bottle motors? And did they work?
is that the two plugs attaced to the bottle itself.
$20 comes with free bottle haha
definatly both worked
Please PM me price for radiator shroud (if great/perfect condition) delivered to 2087.
Also air diverter actuator (fresh/recycle air actuator) please!
-Steve
Pm sent randy
and up it goes.
Come and get it. new car won't fit in garage if this stuffs here
Any one interested in a complete complianced shell. no engine, no gearbox, no diff,
has wide bodykit moulded on
hey mate do you still have the driver side window switches plastic? and the passenger side interior door trim with the window switch and where abouts do you live
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
