Item: 1993 Nissan Skyline R32 Gts-t Type M
Item Condition: Excellent.
Price and payment conditions: $11,599 with front-cut and other skyline parts (listed below)
Or $9,499 without parts
Car is currently registered till Nov 2010 and will be sold with RWC.
Engine & Drivetrain:
• 5 Speed Manual
• RB20DET [171xxxkms]
• R33 turbo
• Splitfire coil packs
• Trust Front Mount Inter-cooler
• 3” Just Jap front pipe
• 2 1/2” inch aftermarket exhaust
• Drift Oil Catch Can
• GFB boost controller
• K & N pod air filter
• E-manage Blue
• GTR Injectors
• GTR resistor pack
• GTR fuel pump
• New water pump
• New Gates racing timing belt
• Adjustable Cam gears
• Excedy Heavy Duty Clutch
Suspension & Handling:
• King Springs and KYB struts
• Rear arms changed, receipts provided
• Hicas Lock Bar Installed
• Cusco front strut bar
• Cusco rear strut bar
Brakes & Wheels:
• DBA slotted rotors x4
• Running Bendix Ultimate pads
• R32 GTR Rims
• Front Tires – 225 Continental Contact Sport 2
• Rear Tires – 225 Toyo’s
• Tires have been replaced recently
Interior/Exterior
• Apexi Boost gauge
• Turbo timer
• New leather handbrake & gear lever covers
• JVC Head Unit with 6 x 9's and Sony xPlode Amp
• Windows tinted
• Drift leather steering wheel (not installed)
• Drift car covers
• Alarm/Immobiliser/keyless entry
I've owned this car for over two years now and I've never had any real trouble with it. I've replaced a few things that have worn out like the clutch slave cylinder and the power steering hoses. Turbo has been upgraded to an r33 item and dyno tuned at Revzone. I also had a major service done with new water pump, timing belt, seals & crank angle sensors replaced. All receipts and service history will be provided for interested buyers. Car has only been run on 98 octane fuel. Every 5000 k's engine oil and spark plugs have been changed.
For $11,599 I will include all my skyline parts with the car including:
• R32 Front cut
• R32 Front Ohlins Shocks
• R32 Front Tein Shocks
• aftermarket R32 front bar
• standard bonnet
• HKS blow off valve with RB plenum
• stock R32 turbo
• 4 stock r32 rims and tires
• 3” inch straight through cat with cannon muffler exhaust
• 2 spare 16” tires good tread
• Stock R32 GTS-T coil packs
• Stock R32 GTS-T injectors
• 2 brand new Bendix Ultimate rear brake pads
• 2 Front RSR Springs
• stock fuel pump
• original exhaust
• original air box
• original inter-cooler
• fog lights
For $9,499 I will sell just the car.
Car also comes with engineers certificate. Price is negotiable.
For genuine inquiries, please contact Lachlan on 0412 583 844 or PM.
https://www.sau.com.au/forums/topic/315569-1993-r32-gts-t-parts-melbourne/
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
