Hi guys and girls
this was our test adatronic e420c ecu we used to test on our r32 gts4
it has had about 5-10 hours use on the dyno so basically brand new.
Please find the link below with the full spec sheet of the Adaptronic
It will include the ecu with a plug in loom for r32,33,34 gtst,gtt and gtr it will also have a 3 bar map sensor so you can ditch the afm.
We can also fit and tune it at additional cost.
Price is 1200 shipped
contact on 0438 804 282 or pm
http://adaptronic.com.au/products.html
Also want to note you don't need an afm to run this ecu acts le a power fc d-jetro with a map sensor
also this ecu can be used to run traction control as well
Can you give me an idea of cost to fit and tune onto a 25 with FMIC, exhaust, pod and 9psi if I bought this from you?
Pm sent mate.
Yeah they do have lots of nifty function I wouldn't bother with the bee r as you can do the same thing with the ecu in the rpm limit control to cut the timing and not fuel or the other way it's user defined
I'd love it, but I only have a gorilla to play with so will going a Nistune w/AFM.
I can get you nistune if you want as well
I have a Z32 ECU on the way. Once that lands I'll start figuring out who I'm going to go with. There are a few reputable guys on here who I will be considering.
Hey mate it's allready 150 cheaper as it been I'm test car on the dyno for a few hours so I thought 1200 shipped was pretty fair for it
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
