Hey guys,
Have searched this subject with no luck. I'm chasing a MFD to install into my GTR because I want to monitor all
my cars vitals without the clutter of 6 gauges on the dash.
I have a haltech E11 v2, but dont want to replace my dash with the racepace ones.
I've heard the Japanese brands Greddy ect, dont connect or sync properly with Australian or American ECUs.
Is this correct? So I guess my question is anyone know of any MFDs that I could use??
Or has anyone got MFDs with the Haltech?
Any help much appreciated
Cheers Mick
https://www.sau.com.au/forums/topic/315774-mfds/
Anyone using Ask Design or Defi multi function dashs?
I had the defi display unit in my old 32, used it as a speedo and water temp sensor, never got around to it but was going to add oil pressure and oil temp. you can also add exhaust temp, fuel pressure and boost ( i had a seperate defi boost guage)
Its an awesome unit, you can set max values and then it will alarm if it gos over, which you can also get a seperate LED light for, you can customise a few different things, PSI or BAR, kmph or mph, stuff like that.
in general i loved it and wouldnt hesitate to reccomend it, only thing is some might say the display is a bit dated, its just a single colour (brightness adjustable) pixelated display. But this didnt bother me, was still fully siiic
theres mine (well, was mine)
edit: just read your whole post, are youo talking about the full defi dash or the display i am on about ?
https://www.sau.com.au/forums/topic/315774-mfds/#findComment-5172363
unsure on the costs behind it but HKS CAMP or HKS CAMP v2 is basically this
a full MFD display which you run to your own TV unit in the car
so you can choose the screen even a $150 ebay ching chong LCD display for your car would be prefect
https://www.sau.com.au/forums/topic/315774-mfds/#findComment-5172410
[quote name='thrtytwo' date='9 Apr 2010, 02:51 PM' post='5172363'
Yeah mate a display like yours not a dash sorry.
Just need to find out if the Haltech configures with them.
https://www.sau.com.au/forums/topic/315774-mfds/#findComment-5172940
Does anyone know if Jap brand MFDs work on Haltech ECUs?
Cheers
you would probably need to hook it up to the factory sensors or install ones that work with the unit if you use haltech specific ones which i know the older haltechs use to.
https://www.sau.com.au/forums/topic/315774-mfds/#findComment-5173476
What do you want to monitor?
have a look at Ruzic EM Pro II... awsome piece of gear.
Hey XRATED,
I mainly want to monitor oil pressure, oil temp, water temp, voltage and intake temp or exhaust temp.
If the displays can do more than this ill hook them up to.
I just looked the Ruzic EM Pro II and your right that is an awesome piece of gear.
Any idea of cost or suppliers??
Thanks
https://www.sau.com.au/forums/topic/315774-mfds/#findComment-5173488
saw the greddy thing today....looks as cool as it you would think!
I run the Ruzic Engine Monitor in my race car...pm Mountainrunner on here to get hold of one. Excellent piece of kit at a fraction of the cost of similar things, but you will need to know wiring to install it, or get someone to do it
https://www.sau.com.au/forums/topic/315774-mfds/#findComment-5175161
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
    • There is an ABS pump and a few solenoids. You could trigger the front/rear solenoids with a pressure bleeder attached with a Consult 2.
