Hey all,
up for sale is my Pride and joy.
Forged RB30/25 only done 4000k's still on run in tune as i cant afford to get the full tune done, Made 350hp at the wheels at 5000 rpm on run in on 18psi, will make 500 on full tune
Running Autronic SM4 ECU
Custom Respray in Solid Blue inside and out (including engine bay)
Gtr front bar/Bonnet/Grill
Vertex Side skirts and rear Bar, Vanquish Roof Spoiler
hand Flared front Guards,
Gtr Front and read Seats
Custom Tail shaft
Kazz MEchanical 2 way Diff
Cradle spacer Bushes (alloy)
Solid Steering Spacer
Tein Coil overs
Rear Upper Camober arms KTS
Adjustable Castor arms
Nardi Wheel
Apexi Boost gauge
Greddy Exhaust Temp Gauge
Hicas Lock Bar
Bosch 044 external pump feeds the 680cc injectors from the surge Tank
Gtr in tank lift pump
Hundreds of $$ in speedflow and braided hose
Plumb back Greddy BOV
Custom Exhaust manifoild and 4 inch exhaust
Custom Intake Manifold
Custom Intercooler Piping
Custom Oil Catch can (returns to sump)
Custom Baffeled Sump
PWR 81mm Intercooler
42mm Alloy Radiator
60mm Pro Boost External Wastegate
Garret GT35R 1.06 rear
RB25 Gear box
Work emotion CR Kai 17x 9 +17 offset i think in white
Clear timing cover
Spool adjustable Cam Gears
URAS Handbrake Pads
there is plenty more but i cant think of it all right now.
Feel Free to ask any questions
Located on the gold coast
Asking $31,500 ono (have receipts for 60K)
Phone or sms Brad 0450 194 170 or PM me here
Selling so i can buy a house,
i also have a JZX100 for sale
Pics Below
http://img704.imageshack.us/i/post6151259487633185382.jpg/
http://img231.imageshack.us/i/imgp4274.jpg/
http://img176.imageshack.us/i/imgp4273.jpg/
http://img41.imageshack.us/i/imgp3171.jpg/
http://img192.imageshack.us/i/imgp3174.jpg/
http://img200.imageshack.us/i/imgp4080h.jpg/
https://www.sau.com.au/forums/topic/315803-r32-4-door-rb3025/
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
