not everyones got mad skills like you bubba :happy:
25 with box drive in drive out 6k (stock)
30 drive in drive out 12-15k (forged)
budget another 6k+ for a turbo setup and 2-3k for fuel then you should be right
not everyones got mad skills like you bubba :ninja:
:happy:
The latest iteration of my 30 is up around R32Drivers estimates.. what with brand new Garrett turbo, 6boost manifold, 50mm gate, 1000cc injectors, stronger internals etc etc.
500rwhp ain't cheap :P
Edited by bubba
If you want to complete the 26 conversion I'd budget near the $10k mark once you changed your gearbox, clutch and all minor bits and pieces.
Whats a 26dett go for these days with wire , ecu n afms ?
Bubba refrain from posting about your rb30 dreams and I will reward you with a carton of emu export.
Dreams schmeams.. they are so close to being a reality that it's going to cost me more money already lol
Export.. with Jacks you might have a better chance :D
hey guys thanks for all your help ;) im goin with the rb25. now i just done no which one to get the s2 33 or the 34. i was told by hyperdrive the 34 neo was better but i dont no? i wanted to see what u gurus rekon. and ill be changing the gear box aswell so im guessing ill be getting a halfcut does anyone no roughly one will set me back
thanks boys
As soon as my motor blows in my 32, im gonna drop a 25 neo in mine... how much work is it??? close to a straight swap with the 20? same engine mounts, etc???
i had a search but cant find any build threads on ppl that have done it...
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
