Anyone In The Doncaster Area Wanna Help Out A Fellow Skyliner?
Hey guys,I posted up a thread about bleeding my clutch,well everything I tried has not worked and I'm out of ideas. I was replacing the clutch slave cylinder and did the bleeding procedure but it's not working,I got no pedal and can't move the car.
I was wondering if anyone in the Doncaster area would like to come down and have a look,see if I'm doing anything wrong.
Any help at all would be much appreciated. I'm there now tryin to figure this out..
You can call me on 0401157085
thanks guys
Ben
thanks guys
Ben
you need to bleed it at the junction box too
follow the clutch master cyl on the firewall down towards the gearbox, it wont go straight to the slave cyl on the gearbox, it will go into a junction box thingo first... then it will do a big loop, and then come back and go into the slave cyl on the gearbox.... anyways the little box it goes into first has a bleeder nipple on it!
you need to bleed that too!
remember when you have someone else pumping the cluch pedal, they need to hold it in to the floor before you can crack the bleed nipple open, then shut the bleed nipple again before they remove thier foot, then proceed to do this again
do the slave slave first, then the junction box
remember to keep plenty of fluid in the master reservoir while your bleeding, dont want to suck more air in...
Edited by Ruffels
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
