Recently installed new body kit and wheels and now ill be moving and i cant take the factory parts with me.
Parts are from a Gt st 2 door r33 series 2 1996
ill be selling all body kits, wheels with tiers and will throw in a new grill to.
if have a good eye you can see handy work that was done to install a inter-cooler
paint chiped off
only used ones to get me from Vic to Adelaide. Still good condition
and the free grill that i got from viva garage
if possible i like it to be over $450 to cover the moving experience
and in Adelaide
if any question just ask
Hey mate, interested in the wheel and grill if you can post them to 3806. How much are you asking for the wheels? If you don't want to post the wheels, then how much for the grill delivered?
Cheers
Cheers
im still looking for a cheap delivery but the wheels are 300 for the 4 wheels and tyers
how much for the front bar posted to 3802 VIC please?
front bar is 150 still trying to find good delivery, but tnt is 37.17+gst 2-7 working days, 100 more for lost or damage but this is baste on another web page on quots
Cheers
it looks like around 56 i think, but ill find out when i ring up, close now
Cheers
yea its the original
thread if its the mid of this
its 4mm
360 for both side and wheels with tyres
smart send $75
its 4mm
smart send $75
Cheers mate, so all up $375 delivered. Umm, I'm gonna see if I can find any cheaper set local, if not I'll get in touch with you. :happy:
Hi Bud, How much for the bumper without the fog lights?? posted to melb
u mean without the fog lights and the indicators?
$120
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
