Nsw - Want To Swap Rb20det R32 Gts-t & Rb25det R31 For Fairly Stock R32 Gtr, Or Maybe R33 Gtr
Hi guys, as the title suggests, ive got an R32 GTS-T & an R31 with an RB25 motor that i want to swap for a fairly stock R32 GTR, or R33 GTR if there is 1 that cheap.
Basically i bought the R31 for the motor, which is from an R33 GTS-T Series 2. I plan to use it in my R32 GTS-T, although ive always wanted a GTR. I also have a few items that i have acquired for the conversion as well as spares that i would trade with the cars if a GTR owner is interested in the swap. Im looking for a straight swap, as all my money has gone into acquiring these cars & all the extras i have for the conversion. These extras would include:
R33 GTS-T front calipers & rotors
Apexi Power FC for RB25 with hand controller
Z32 AFM
GTR injectors & resistor pack (stock but reco'd)
White R32 GTR bonnet & grille in perfect condition (not a dent)
The R32 GTS-T specs are as follows:
1992 R32 GTS-T (my current daily driver)
5 speed manual
wine red metallic
18x,xxx kms
BLITZ front mount intercooler
UAS cerametallic clutch (single plate)
rebuilt & shimmed factory LSD
Blitz BOV (disconnected) & Turbosmart BOV (plumb back)
Splitfire coil packs
3" exhaust
dual stage boost controller (11psi & 13psi setting currently on standard turbo)
18" white 7 spoke rims with good tyres
slotted front rotors
all urethane rubbers in the front suspension
R32 GTR front seats
CD player
2 pillar mounted gauges (boost gauge & air/fuel ratio)
500hp in tank Walbro fuel pump
pod filter & R32 GTR pod cover modified to fit
RB25 pink label AFM fitted
insurance approved 3 point alarm & immobiliser with auto window lift
HKS turbo timer
made 145.5kw at the wheels (before pod filter, diff rebuild, AFM replacement, new clutch because stock clutch was slipping, split fires), can get dyno run now for the new owner. All my tuning & performance work has been done at Unique Auto Sports.
R31 specs from what i know are as follows:
R31 sedan
RB25 from S2 R33 GTS-T (unsure of kms when conversion was done)
fully engineered for conversion, have engineers certificate with car
big front mount intercooler with custom piping
rebuilt 5 speed R31 gearbox
rebuilt factory R31 diff (non-LSD)
2 sets of 4 stud wheels, 1 stock set 1 multi spoke set currently fitted
alarm with central locking, built in turbo timer, 3 point immobiliser option fitted, all black wiring
3" exhaust
Microtech LT8 ecu
turbosmart boost t piece running approx 8psi
made 150kw at the wheels running all stock gear with Microtech LT8 ecu currently fitted
also have some random misc spares for the R31 that i havent looked through closely yet
The R31 is not registered, & has been kept covered up until i am ready to pull the engine out of it if it does not go before hand. It gets started every week or 2, & just driven around the flat parts of the paddock to keep everything moving.
If anyone would like any more info or pics on either of the cars, PM me or email me at:
[email protected]
You can also msg me for any details you may be after, or for any offers on 0407 896 339.
If i cant find a trade, il go ahead & do the conversion in a few months like i had planned. I have been after a GTR for ages, & i would like to acquire 1 sooner rather than later, preferably an R32 GTR.
Cheers all
Im not selling them separately unfortunately.
If i can trade both for a GTR i will do that, if not i intend to keep the R31 to be the donor car for the RB25 to go into the R32.
Until i finish fixing my old daily driver, i cant sell them separately....if i finish that soon i may list them separately, but until then my hands are tied.
to be honest if the 31 is regoed with the 25 in it id sell em seperatly. should be able to get somewhere around the 20k mark between them if in good cond and pick and choose your gtr of choice.
cash talks bullshit walks.
The R31 isnt registered, its engineered though.
Im not looking to sell, as i still need a car to drive to & from work. I bet i could sell the R31 real quick, but the R32 would sit around for ages & no1 would want to buy it.
If i get a trade for both of them for a gtr il be happy, or il be happy if i keep both & go ahead with the engine conversion.
20k would be nice, but i seriously doubt id be getting anywhere near that all up.
yeah he meant if u registered the r31 then sold both of the private u may get around that. and personally thats probably what i would do... i doubt any gtr owner would wanna downgrade to a gtst knowing they would have to do the conversion themselves etc.
Yeah that does certainly make sense, but then im still left with no car to drive to & from work once i sell them.
I guess it was more of a stab to see if anyone was interested in the swap, but i think il end up keeping both & doing the conversion by the looks of things. There could always be a gtr owner who wants something different, after all the whole project is ready to go, but theres not too many of them like you said.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
