These have been in storage for years so they need a new home...
-Technics SH-DJ1200 mixer $350 ono
Good 2 channel battle mixer for scratching/mixing
In excellent condition-hasn't been used much-only selling cause i don't use it
All functions/lights work-original retail price was $800+
...Rare to find in such good condition-its basically looks new-this model has been discontinued but most new replacement parts are
still available online or from Technics/Panasonic
...None of the faders bleed/leak sound-runs on 240 volts-has an Aussie plug so just plug in & play
Can be connected to other mixers so you can hear [scratching/mixing] from anything connected through 1 set of speakers/amp at the same time
CHECK THIS LINK FOR MORE INFO [sH-EX is basically the same]
http://www.panasonic.com/consumer_electron...cs_shex1200.asp
-Technics 1600 MK2 turntable $300 ono
Headshell,cartridge/stylus & plastic cover arent included-doesn't have one
...This is basically the automatic version of the Technics 1200/1210 DJ turntable
Has the same tonearm/assembly,popup light,platter & magnetic motor [is direct drive & can be used for DJ'in/scratching]
Runs on 240 volts & has an aussie plug-so just plug in & play
...Has some scratches & blemishes but the paint on top surface is in VGC for a deck this old
Not all functions work but could be repaired by yr local Panasonic/technics technician
Cue function works-hit the button & tonearm automatically lifts & moves to start of record
...Repeat/tonearm return [at end of record] doesnt work
All lights work including popup light
Pitch control works
The RCA cords & ground wire are in VGC
...If posted it will be packed securely surrounded by slabs of thick foam with the platter & counterweight removed & the tone arm locked down,etc
To protect to tonearm/assembly during transit ill tape down a thick block of packing foam where the platter would normally sit
then the top of box will be well above the tonearm
Pair of dark blue Technics 1200/1210 coverplates $80 ono
...Not damaged or buckled-easy to fit-sits ontop of faceplate
In near new condition-a few very light marks but hardly noticeable
Easy to repaint in any colour [gloss black will look good] or get chrome plated
...Makes old scratched/faded decks look new again & protects the surface
I think the brand is Oddessy-bought them 2nd hand-they fitted my 1200 MK2's perfectly
Can deliver within 100 K's of Sunny Coast for extra fuel $ or send with aussie post
Pickups from Maroochydore-Sunshine Coast-QLD
https://www.sau.com.au/forums/topic/316996-dj-gearsunshine-coast-qld/
Also selling a VGC black Technics 1210 MK2 turntable $400 ono
Plastic lid is included-everything works except for the popup light
Has a few light scratches-can be sent with aussie post
All serious offers considered on anything I'm selling
Technics 1210 MK2 turntable is SOLD
Some pics of the coverplates-the flash on camera makes them look alot lighter colour than they acually are
was going to paint them gloss black but didnt get around to it
SH-DJ1200 mixer pic isnt of actual item but mines in the same condition
dont have my digi camera atm but can get pics of if to send before selling
All other pics i've added are of the gear im selling
Also have another black Technics SH-DJ1200 mixer i'd sell $200 ono
it has some scratches & marks but is otherwise in good condition
everything works-just needs a new crossfader which costs about $70-$90 online
It's now missing a line/phono gold switch but you can still move the base of switch[just underneath faceplate]
with a bit of plastic
the crossfader works but leaks sound - power cord's included
The gold paint on the EQ's & trims was almost worn off so i chucked some stickers on them
This is a basic scratch/DJ mixer
Was the only model allowed to be used in the DMC world championship comps for years until they changed the rules
Good to learn on & easy to do tricks/effects cause everthings close together
...now $150
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
