This strarted happing bout a week ago and i dont want to have to put it on the dyno just to find out whats wrong any help much appreciated..
first up my mods are on my r32gtst
mines ecu
splitfires
r33turbo
trust cooler kit
hks pod
split dump and full 3inch exaust and a removed cat(no i did not do that so dont comment on it i no its a shit idea)
tomie fuel reg (no gague)
intank walbro
excedy cushion button clutch 5000k old
my clutch fan ceased and while i was driveing with the shit clutch fan this started happening not sure if its related but yeah
have put a better one on there but still when i drive the car past 5500rpm i get boost creep and with the boost creep comes the dead reving (now when i say dead reving i mean the car keeps reving but the reving slows down and you can feel the power drop off which i dont under stand you would think as the boost creeps the power would rise right
i thought i had faulty actuator which i did the spring was shat and i have changed that boost is more stable but still creeping and still dead reving
i was also wondering if it could be leaning out and the ecu is retarding the timing to stop it detonating i have heard the mines ecu will do this but because of what it just started happening
i thought maybe Bad fuel or maybe blocked filter so i changed the filter and ran fuel system cleaner and it got a lil better but still is dead reving
another thing is the when the engine is cooler and you show the car some love its fine for the 1st run but after that it starts dead reving as the car gets hotter
Could there be something getting heat soaked???
one other thing i thought is that i have plumbed both the breathers on the rockers into a catch tank and then back out the catch tank into
the intake pipe
now the pipe that was going to the pod was heating up and sucking shut which isnt good but has sinced been replaced with better hose and that problem is fixed but it blocking the breathers could that haved fubared a pcv valve or something its a long shot but anythings worthago
sorry for the epic thread BUT I NEED HELP ASAP
https://www.sau.com.au/forums/topic/317054-boost-creep-dead-reavingr32-rb20det/
just a quick question
before you start the compression test do you have to disconnect the electricals like ignition module etc ?
what compression test i have had it done once and that was by my tuning shop
as far as i no you just remove your sparkplug screm your tester in and manually wind the motor over
but not 100% haven done it personally
anyone else can you help me out???
i dont think all do, but theres a fair few i know of that definately do, check it manually and see if its free to swing open... what sort of boost pressures is it creeping to? whoa jason ive never seen the standard map before, that runs a hell of a lot of timing in the mid range at light cruise
yeah will pull it off in the morning and check that i had it set to 12psi on the hks evc 4 but would creep to 14psi but thats gone now and its just running the standard setup and is creeping to 14psi still i will check the dump and let you no how i go thanks guys
j took the actuator rod off the wastgate flap today and moved the flap manually seems with a push down on the flap slightly and try and move it open and closed it gets caught on something like the inside of the dump i will have to pull it off to really find out wats going on
also should there be some up and down play in the actuall flap or should it sit solid i have about 2mm of play???
thanks again
its hitting the middle of the split bit of the dump that seperates the wastegate and turbo exhaust gases, maybe try grinding out enough from the divider so the waste gate doesn't foul on it
yeah i will mate thanks
but y do you reckon its just started doing it????
the car was fine and then one day it just started doing it maybe heat shrink thats all i can think off unless the exauhst is starting to sag possibly because there is no hanger on the after market front pipe???
is there anything else anyone can think off that would cause this
Colder nights?
nah it happens all the time during the day at night whenever it wants
the only time it doesnt do it is the first time you get into it
is it possible my bov could be leaking its a drift vent to atmo its a year old but would the pressure loss under load cause my problem
Thanks again
yeah if it was leaking enough it cause these issues. Can you tighten the spring on it?
it is a drift adjustable one you can just turn the top to hard i will do that tommoro before i go to work it would be great if that was the issue lol
well that isnt my issue gonna take the dump off now check all vacumm lines cant think of anything else it could be
put a standard dump of my rb20 turbo today and there is still a spot on the standard dump where it seems to catch and i stilol have the same issuse i must have soime sort of air leak or something cause i cannot find the issue
Sounds like your timing is retarded?
yeah it feels like that but i dont no why it just started happening
if the CAS(crank angle sensor) is faulty or somehow loose do you think it would cause my timing issues making the turbo boost creep
i have also found a decent exauhst leak from the flanges the cat bolts to under load it would leak a fair bit is it possible there could be some sort of pressure loss or drop causing the boostcreep and timing retarding
I have seen upto 5psi more boost in a GTR with the base timing retarded 12degrees. You need to get it to a well respected tuner because I'm just speculating here. Its the type of issue I would find in 10min on the dyno.
yeah its booked in i just would have liked to have been able to deal with the issue myself but oh well will update shortly thanks
im gonna change the ecu and see if that does anything.
The new ecu i have is an auto one.
now i no you can run a manual box behind a factory auto and bridge the neutral/drive switch telling the ecu its in park not drive but will there be anything on a factory manual loom that will need to be tinkerd with to run auto ecu behind a factory manual car
or will it be plug and play??
this is only to see if my current ecu is working or wheather thats the problem
Thanks
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
