Hey guys signed up here so i could learn a little bit more about skylines. In a few months i'm going to be buying a new car (read: most probably importing one) and recently i have been considering a skyline as this possible car. Im only a fan of the r34's and in particular the GTR's, however from looking at some GTR's they will be stretching the budget to the limit so i need to arm myself with as much info as i can find on them and then see if its worth the money. If anyone is wondering the other cars im looking at are: Jza80 RZ supras and Evo's, now i know a lot of people are going to flame me over the supra but its been a dream car for a while and a lot more affordable than the GTR with room for a mod budget straight out, same goes for the Evo (prob a 7) but many people are saying spend the money and buy a GTR. So yeah will be kicking around here learning as much as possible and asking a lot of dumb questions probably!
Now for the first one, how possible is it to daily an r34 GTR? not that i will be, the BMW will stay in that role but its a good indication of how driver friendly a car is for me.
thanks guys
andy
https://www.sau.com.au/forums/topic/317071-hey-all-new-around-here/
Hiya Andy & welcome, :)
For a while I had both the R34 GT-R (still in my possession) and the E46 328Ci (also a manual).
As a daily, the R34 GT-R is quite acceptable, since it's not too hard on the bum.
It's probably a waste of a clutch if you have to drive in peak hour traffic.
To buy a good one, I'd keep $43K as a budget; with $37K buying you one that would have high Kms or uncertain history or risk of problems. Yes, importing one will save you $$$.
Try several before you buy and look them over for service history/damage/rust (which can be checked for Japanese prefecture origin through VINS Fasted thread on this forum).
If you get a good one, it's an extremely potent race car disguised as a street car.
PM benro2 on SAU here for pros and cons of a supra since he has a skyline too and is familiar with their idiosyncracies
The Supra is in a totally different price bracket than an R34 GT-R though.
Thanks for the reply, ill keep looking around as the funds wont be available for a little while (prob closer to the end of the year). I like both cars but for totally different reasons, the gtr appeals as the best you can possibly get; quick, as well as being a very good track car outta the box, while the supra is a lot cheaper and i do like the look of the supra, esp the inside which i find quite lacking on the r34's. Also if i go the supra route im looking at half the price for a clean RZ and then enough money to go single and look at 700-800 horses which is very very tempting, i guess it comes down to if i want to be able to go around corners or not.....
Well I don't think you'd regretting procuring 2JZ. Their conrods and pistons are stronger/bulletproof. They're ergonomically sweet inside as the driver is totally catered for.
The R34 is so brilliantly upgradable and still not break traction on launches & sweepers.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
