Need more Zed Pics!
Sure thing...
Any more pics of the Impul R32 GT-R thanks
Sorry; haven't got any other pics of it :blink:
nice pics! got some talent!
Thanks a lot :(
awesome pics
Cheers! :)
nice shoots man very nice keep up the good work
Thanks a lot :blink:
A week back i covered a dance performance and it was one of the toughest gigs i have ever done. The change of lighting every second, the fast dance movements, not understanding what the dance meant and the stage being about chest height.. But i had fun which is the main thing and didnt do too bad. What i found was that when i shot with a 70-200L lens, it produced a little less noise at 1600 compared to a 50mm f1.4. Oh and did i mention the people in the front row with digi cams taking shots with flash every 5 seconds.
I hate that; taking pics with people with little point and shoot digital camera's having bursts of flash going off just as i'm about to hit the shutter, happens all the time!
Some really amazing photos in this thread! Very talented.
Thanks a lot, really appreciate it :)
good job man keep it up
Thanks, will do :)
______________
Got a few more pics from a recent meet-up
  • 2 months later...
do you use filters or polariser when taking these to bring the contrast or colours, or is it all post production work?
Nice pics, I am very much an amature but I enjoy learning and experimenting with my 40D...
Nice shots mate, looks like your getting HDR down pat!
It's all HDR (High Dynamic Range).
Basically you can take one RAW photo and create a single HDR by adjusting it +/- 1 or 2 stops and then stack them.
OR
Take bracketed shots (3-9 shots at different exposures all a stop apart) and then combine them in photoshop or Photomatix or any HDR compatible program.
Plenty of info out on the web about it :down:
OR
Thanks, I will try that...
Those two blue 34GTR's really look nice with the HDR effect. I think it suits the photo.
By the way, you need to clean your sensor! If it's not your sensor, you need to clean your lenses and/or filters! So much dust spots in the last two photos!
I'm only using a UV filter on it, the contrast/colour work is all post production.
nice shots!, i think the 32GTR ones look best
These are so nice. Well done!
Thanks!
Great! It's very nice. :huh:
Haha yeah, it's cleaned now :D I looked at the photo once I uploaded it to my computer and I was like :O
__________________________________________________
Might as well update this with a few of my most recent shots...
  • 1 month later...
Here is some HDR photo for my 350z too
I took 5x shoots using same aperture but difference shutter speed and using "Photomatix Pro" in the mac to marge to HDR.
What program do you guys use to Marge to HDR?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
