thinking of selling my shell,
would be suitable for TRACK ONLY CAR but still has vic rego til june,no defects at all
shells pretty cop,rattle can paint job etc
will have on it-
gtr front bar
new windscreen (2 laps old lol)
coilovers
hicas lock bar
locked diff
lock spacers
60mm radiator mounted in front of rad support
custom removable rad support
twin thermo fans
3' cat back exhaust
STRIPPED interior!
june vic rego
stock gtst rims with rwc tread
complete other than engine package,still has all the brakes etc
pics of green is what it looks like now
and black thats underneath haha
$1500
$1000 with stock suspension,no rego etc
located northern suburbs adelaide
0431683303
CAR WOULD ONLY BE SUITED AS TRACK CAR<DONT WANT ANYMORE PEOPLE RINGING OR LOOKING AT IT AS A STREET CAR!!!! Attached thumbnail(s)
https://www.sau.com.au/forums/topic/318229-r32-drift-shell/
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
