sadly due to financial reasons im going to have to sell my super-awesome-massive-dish wheels.
they are Weds Kranze Shoki, a quality Japanese wheel.
5 x 114.3
sizes are 18x9 fronts (ill have to check the offset)
and rears are 18x11 -15.... yes negative 15
overall condition is good, they have a very very minor rash marks, visible in the second picture, and the stickers are a little worn, will look great with a good polish.
wheels do not come with tyres.
serious wheels so asking for serious buyers only...
asking 2.5k. all serious offers will be considered
located northern beaches, sydney, might be able to arrange freight too if required.
wow i wish u were in Bris would love to see how these would fit on my 33, posting rims seems like a pain in the arse cost wise??
Aussie post will take box's up to 20 kgs
if dimensions of box is too big[for tham to accept]just crush/tape down the corners
then its charged by cubic volume
shitloads cheaper than courier services
just curious how much does each rim weigh?
    • If your tuner can't make the car idle like factory, I'd get a new tuner. These injectors are fantastic and I'd have very serious concerns about a tuners skill set if they couldn't get them to idle well.
    • It's highly likely you will find something. Alternatively, a quick design and order online from chaina and you'll have a perfect solution
    • Idle Lambda target is off by .4 but I reckon the VE table is not correct. If my tuner has no issue using these injectors I will keep them, they are good quality after all
    • I already have an Apexi. Just wondering if it is worth putting in something new since the Apexi is likely well over 10 years old, if not 15. I know the injectors work but they already run at less than rated fuel pressure to make them work properly and idle is basically 1% duty cycle or less. Could be better
    • Nice, I would never have thought in that direction. The actual motor is a cylinder....I wonder if there are any cylindrical heat sinks with the right ID  (and if there is clearance to other components). I think adding airflow is still a thing as well....will check it all out next time it is in the air. Wish I had a hoist...
