I've got a C's replica quickshifter for sale. Last from a group buy. These are new and I'm after $240. The price isn't negotiable as this is a fantastic price for a new quickshifter. Will fit s13,s14 5 speed boxes and will also fit rb20, 30 rwd boxes. Not sure about rb25 though.
0401669900 or pm
Cheers
Jayson
Ps. Im in brissie
https://www.sau.com.au/forums/topic/31893-fs-quickshiter/
hehe, stupid me. I have been calling them quickshitters just as a joke, now im writing it down. Stupid!!! lol
For those with rb25's and rb26 boxes. I went to the shop where i did the group buy thru today. I can get the rb25 and 26 ones now but they are $260. The one i have for sale won't fit the rb25 and 26 boxes sorry. If your interested in one of them pm me, but back on topic.
Quickshifter for rwd rb20, sr20, ca18. $240 new!
https://www.sau.com.au/forums/topic/31893-fs-quickshiter/#findComment-642833
Quickshifters reduce the throw distance in between changing gears and make your car quicker by A: being changed into the next gear while losing less revs and
B: Quicker changes because of the shorter throw.
They made a big difference for me cuz im a big slow bloke and it helped heaps for those traffic light show downs that some people get into on the odd occasion at willowbank raceway!
Im in nudgee/northgate
https://www.sau.com.au/forums/topic/31893-fs-quickshiter/#findComment-643361
pics here
Here is a pic of one, the gear knob isn't included.
The shifter may be a tad shorter but nothing major. The shift between gears is dramatically shorter and i was very happy with mine when it went in. If your in brissie you can try mine by all means.
Cheers
Jayson
https://www.sau.com.au/forums/topic/31893-fs-quickshiter/#findComment-643653
http://www.pdm-racing.com/installs/sshifte...help/sld001.htm
this link will give you all information for installation. It's very easy and the kit comes with all stuff needed. I think from memory the stick was about 1cm or so shorter in length and the difference in shift was heaps.
https://www.sau.com.au/forums/topic/31893-fs-quickshiter/#findComment-643664
its called short shift kit not quick shift, sorry
If you wanna be pedantic about it, the C's box actually says "Short stroke shift". But short shift or quick shift are equally acceptable terms for these items.
https://www.sau.com.au/forums/topic/31893-fs-quickshiter/#findComment-645447
    • Thanks for that mate always a good help
    • It's not really a calibration issue, if the voltage is really at 2V. If the voltage is 2V, then that's what the TPS is putting out, and the Haltech is seeing that and 2V is about 40% open (you know, between 0.45v being closed and something close to 4.5V being fully open). So, that would suggest that the TPS is maladjusted, on crooked, something something something. Or a wire problem.
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
