Vehicle: 1998 NISSAN SKYLINE R34 GT-T
Price: $20,000
Kilometres: 109,500
Body: Coupe
Colour: SILVER
Interior Colour: GREY
Transmission: 5 speed Manual
Engine: 6 cylinder Petrol Turbo 2.5L (2498cc)
Reg Plate: XPV503
Reg Expire: MAR-2011
RWC: Yes
1998 Nissan Skyline ER34 GTT (PRICE DROP)
Imported and complied by GT Auto in Melbourne, this vehicle has had a only one female owner (Non Smoker).
This is the pride and joy of a fastidious owner who regularly cleaned and maintained this machine. Regular maintenance has recently included the replacement of engine timing belt, water pump and idler bearings. This vehicle is running perfectly with a standard tune however the sale will include fitted extras including HKS GT-RS Turbo, Exedy Button Clutch and 3 inch HKS exhaust system.
Bonus handling improvements include Apexi adjustable coil and spring suspension re enforced with front and rear Nismo Swaybars.
Inspections welcomed. This car will not dissapoint.
Added extras included with sale:
* HKS GT-RS Turbo
* Blitz front mounted Intercooler (return flow)
* Exedy Button Clutch (5 Puk)
* Apexi Coil and Spring adjustable suspension
* 3 inch HKS Exhaust canon type exhaust system
* Tomei adjustable intake Cam gear
* Bosch 040 internal Fuel Pump
Rego sold with the car is 'XPV503'
Price Negotiable.
Seller Details
Name Laura
Suburb CROYDON
State Victoria, 3136
Mobile Phone 0425 809 945
Features
* 4 Wheel Disc Brakes
* Abs (Antilock Brakes)
* Adjustable Steering Column
* Air Conditioning
* Alloy Wheels
* Auto Climate Control
* Body Coloured Bumpers
* Central Locking
* Drivers Airbag
* Dual Airbags
* Electric Mirrors
* Fuel Injection
* Passenger Airbag
* Power Windows
* Rear Spoiler
* Remote Central Locking
* Tinted Windows
  • 3 weeks later...
  • 4 months later...
hey mate, i have a vk group 3 replica, very clean car, worked 308, engine very healthy, probably done less than 15000kms,
i have it listed on here have a look and let me know, cheers, if u interested in swapping ,0421175527
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
