have just built a house and some extra money would come in handy, this is very regretful and
only willing to let go if reasonable offers are made will post pics up later tonight or tomorrow
car has been well looked after and only used as a weekender. i was trying to make something with more response than overal power and this is what ive come up with.
Vehicle: 1994 R33 GTS-T 2dr
Colour: White
104,000km
sunroof
type 4 viva garage bodykit
Work emotions Xd9 wheels Bronze in colour
18x9 front with toyo proxes4 18x10 rears with nexen tyres (both front and rear tyres travelled less than 5000km)
aftermarket steering wheel
turbo timer
duck tail spoiler
APEXi Power FC
3 inch bell mouth dump and front pipe, Blitz nur spec exhaust cat back
Hybrid front mount
catch can
adj cam gears
Garrett GT2871R turbo 56trim with nissan rear housing
Turbosmart Eboost 2 boost controller
walbro fuel pump
Z32 air flow metre K&N filter
3inch stainless intake pipe with plumb back bov
RDA brakes slotted rears and grooved and dimpled front rotors
everything that is not stock is brand new travelled no more than 6000km
car was tuned by jeff at speed lab
produced 275rwkw on 16psi and 480nm of torque
assures me it is a safe tune and car is capable of more but the turbo is only small
tuned to run 14psi on setting 1 and 16psi on setting 2 comes with print out
not really sure what its worth but was thinking 17,000 or 16,000 (all offers considered)
contact Jason 0433626679
will upload photos of the car with xd9's once i have taken some but im sure everyone is aware what they look like
Edited by jason_33
https://www.sau.com.au/forums/topic/319557-eoi-370rwhp-r33/
Very nice and quik 33..didn't think I'd see ya sell it mate..
Since Jase has owned this never once seen it be mistreated,and has been looked after well..very nice example of a 33..I think being in it and feeling what it has to offer gives it true justice...good luck with the sale...nice car worth the price,especially knowing the work done is very recent and reliable..
https://www.sau.com.au/forums/topic/319557-eoi-370rwhp-r33/#findComment-5218981
Colour: White
104,000km
sunroof
turbo timer
duck tail spoiler
APEXi Power FC
Hybrid front mount
catch can
adj cam gears
walbro fuel pump
not really sure what its worth but was thinking 16,000 - 15,000 (all offers considered)
https://www.sau.com.au/forums/topic/319557-eoi-370rwhp-r33/#findComment-5220114
  • 1 month later...
    • There are black hose clamps as well if you care. Plazmaman for example sells some: https://plazmaman.com/product/black-hose-clamps-premium-quality-stainless-breeze/
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
