Gday all,
I am selling my A31 Cefiro as I can't afford to finish building it into what I want as other commitments in life don't allow time.
Engine: RB20DET
Turbo: stock
Intercooler is stock but car comes with front mount. I had the front mount hooked up but put old stock one on to pass roady.
Seats are stock but comes with R32 drivers seat
Has a Uras looking kit though only front bar is on so far side skirts and rear bar are waiting to be connected.
Diff is stock though comes with R180 locker
Brand new BC Racing TA coilovers
Just Jap adjustable castor rods
Boost gauge
Boost controller
KKRacing Steering wheel
2.5' exhaust is the one I got it with and haven't let her breath with the 3' yet sadly
Enkei Racing Black 17's on the front
16's on the back
Plenty of spares that come with the car
Spare radiator shroud
3' Nismo rear muffler
I am willing to sell parts separately that aren’t on the car but will come with it.
Looking for $8000 ono
Cheers.
https://www.sau.com.au/forums/topic/319589-a31-cefiro-going-cheap/
  • 3 weeks later...
  • 4 weeks later...
  • 3 weeks later...
interested in a series 4 rx7 with s5 mild port motor turbo?
if your cars rego'd i'll chuck in some cash
got a number? where abouts r u from?
http://www.skylinesaustralia.com/forums/Fc...-M-t336053.html
Edited by driftn7
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
