Hi Guys,
Making a new thread with the left off parts from the sale
Brand NEW
RB26 Clear Cam timing cover $100
100mm FMIC to suit GTR Generic/No brand $300
2x Toyo Proxy 18x35x275 BRAND NEW
$500 (retails $500 each)
20x Trust Wheel nuts (Bronze) Very light weight compared to stock nuts
$200
Used Performance Parts
Sard 720cc injectors with Greddy Fuel rail $800 (not seperating)
RB26 Sump with TRUST Sump extentsion welded $700
(Includes R34 GTR diff)
RB26 Clear Cam timing cover (slighly yellow) $60
6x Stock Rb26 rods $150
R33 GTST stock parts
2x Dump pipe $10 each
Front pipe $10
2x Exhaust manifold $20 each
Power Steering bottle $10
SMIC with piping $20
Washer bottle $10
Radiator overflow bottle $10
Pair of indicator lights (clear, front not side) $20
TurboSmart BOV Type 2 $80
Tcc Tech BOV Type 3 $50
R32 GTR boost solenoid $50
6x Stock rb25 rods $50
RB30 head (SOHC) comes with intake and exhaust manifolds $100
PM me with any questions
Located in PERTH but can arrange postage
6 injectors, came off the GTR
less than 10,000 kms
Tyres are proxy 4s
G`day mate! What`s your best price fo the injectors and rail?
For everyone PMing me for best prices
PM me your offer, worse i can say is no
G`day mate ! , Would you take $600 for the 720 injectors and rail? This will bolt on to my R32 gtr?The injector come with spacers to suite?
You know if injector/rail to suit gtr34? (in perth btw)
Edited by Specrzx
Yes it will fit a 32 GTR however it wont come with the spacers
sorry mate, 600 is a tad low
Yes will fit all rb26s
would you take 1000.00 for rail injectors and fmic? if so [email protected]
Edited by nseal14
How about $650 for the rail and injectors? I`ll still have to get the spacers to fit it up. And there is the cost to send it to Melbourne?
  • 4 weeks later...
The rail is still availiable but id rather not seperate it from the injectors
11mm from memory
11mm from memory
Hi, Steve, location?
Does the extended sump come with batfles and trap door,Is the GTR34 front diff different ratio to the GTR33?
you have pm
Tim/Alex
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
