Hi Guys,
Making a new thread with the left off parts from the sale
Brand NEW
RB26 Clear Cam timing cover $100
100mm FMIC to suit GTR Generic/No brand $300
2x Toyo Proxy 18x35x275 BRAND NEW
$500 (retails $500 each)
20x Trust Wheel nuts (Bronze) Very light weight compared to stock nuts
$200
Used Performance Parts
Sard 720cc injectors with Greddy Fuel rail $800 (not seperating)
RB26 Sump with TRUST Sump extentsion welded $700
(Includes R34 GTR diff)
RB26 Clear Cam timing cover (slighly yellow) $60
6x Stock Rb26 rods $150
R33 GTST stock parts
2x Dump pipe $10 each
Front pipe $10
2x Exhaust manifold $20 each
Power Steering bottle $10
SMIC with piping $20
Washer bottle $10
Radiator overflow bottle $10
Pair of indicator lights (clear, front not side) $20
TurboSmart BOV Type 2 $80
Tcc Tech BOV Type 3 $50
R32 GTR boost solenoid $50
6x Stock rb25 rods $50
RB30 head (SOHC) comes with intake and exhaust manifolds $100
PM me with any questions
Located in PERTH but can arrange postage
6 injectors, came off the GTR
less than 10,000 kms
Tyres are proxy 4s
G`day mate! What`s your best price fo the injectors and rail?
For everyone PMing me for best prices
PM me your offer, worse i can say is no
G`day mate ! , Would you take $600 for the 720 injectors and rail? This will bolt on to my R32 gtr?The injector come with spacers to suite?
You know if injector/rail to suit gtr34? (in perth btw)
Edited by Specrzx
Yes it will fit a 32 GTR however it wont come with the spacers
sorry mate, 600 is a tad low
Yes will fit all rb26s
would you take 1000.00 for rail injectors and fmic? if so [email protected]
Edited by nseal14
How about $650 for the rail and injectors? I`ll still have to get the spacers to fit it up. And there is the cost to send it to Melbourne?
  • 4 weeks later...
The rail is still availiable but id rather not seperate it from the injectors
11mm from memory
11mm from memory
Hi, Steve, location?
Does the extended sump come with batfles and trap door,Is the GTR34 front diff different ratio to the GTR33?
you have pm
Tim/Alex
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
