CA18DET engine complete, part of eng loom can be included. (red top eccs) out of a 180sx for sale, suit rebuild.
Reason for sale: Pulled out due to suspected big end bearing fail due to oil surge. Was not started again after knocking was heard. Replaced with a VH45DE v8 so was not needed.
Condition: used, requires check/rebuild
Specs: Was running 225RWKW at 18psi.
Standard bottom end, factory bore.
Stock head with tomei solid lifter conversion (built for high revs). SOLD
Rev limit was set to 8000RPM
Tomei cams 260deg procams, lifter buckets and springs. SOLD
tomei cam gears SOLD
water pump has done only 1000km
Splitfire coils and new coil pack loom. MOST LIKELY SOLD...
Has starter motor, alternator, fan aircon compressor, lightweight exceedy flywheel and ceramic button clutch included (used)
Turbo not included
Suit a bluebird/ datto conversion etc!
Price: $1500 or nearest offer
Garrett 2871R turbo, 380HP, .64 rear end, T25 flange internal wastegate, only seen 2 weeks of use, as new.
$1000ono
Please pm,
Cheers
Sean
https://www.sau.com.au/forums/topic/319825-ca18det-engine-for-sale/
  • 6 months later...
  • 11 months later...
hey mate are welling to seperate aircon compressor is the part number is 926000-52f02 let me know cheersrolleyes.gif
Edited by Dbeast
PM sent.
Engine still here.
Probably part it out.
Engine has the following:
Block: full bottom end complete, light big end knock, suit rebore. $100
Accessories: light weight flywheel,ceramic button heavy duty clutch, 20-30% used $100
Starter: $20
Head: tomei springs, solid lifters and tomei cams, adjustable cam gears. Prefer to sell as a whole $800ono SOLD PENDING
Guest
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
