Hi guys,
Finished tearing apart an RB25DET bottom end. All the bearings had what looked like particulate wear (dead straight scratch from end to end) like some dirt or somesuch has gotten in between the crank and the bearing.... pretty normal for a 17-year-old engine, right?
But... the centre main bearing had a different wear pattern. I don't know what each side of the bearing is named, so I'm making stuff up here... but the side with the annular groove has dark wear tending toward the centre of the bearing, and the other side has very uneven wear as well.
At this point I'm rebuilding a whole new bottom end from an RB30 block, but since I'm trying to learn more about engine building etc I had to ask... what can cause this type of wear in the bearing? Is it just normal sort of wear to see in a main bearing, or is it caused by bad lubrication, fuel diluted oil, uneven load etc.... dying to know.
I've attached pics, adjusted brightness/contrast so the wear patterns come out easier, and highlighted the bits I'm asking about.
Cheers :-)
to my untrained eye the first pic looks like a scorch mark (which would be insufficient oil pressure or really old oil). Not sure about the second pic, mainly just bumping the thread so someone weighs in with some more expertise :(
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
