Item(s) available via the group buy: Genuine Garrett GT3582R, GT3076R, GT3071R, GT3082R, Turbos with 12mnth warranty
Required number of buyers: We only need a minimum of 5 people to get this going guys, and your able to pick any of the GT30 range (External Gate only).... to seal a spot in this Group Buy
Current number of buyers:
1. Luke_GTS-T
2. --Redwork--
Buyers who have paid a deposit: None as yet
Price and price conditions: $1485.00 inc GST for any of the GT30 range (External Gate only).... But we need at least 5 people for this price to go ahead
Import considerations: None needed
Insurance considerations: Can be arranged on freight for interstate buyers
Proof of Insurance: As above
Extra Info: Hey guys, we are pleased to be able to do the Garrett GT3582R, GT3076R, GT3071R, GT3082R Turbos with any of the following exhaust housings 0.63, 0.86 or 1.06 A/R for the cheap price of $1485.00 inc GST. Only conditions of this group buy are that we get a minimum of 5 people to go ahead.
Pictures: GT3582R.jpg
Contact Details:
Ph: Mick on 0438860307
Email: [email protected]
Delivery & Conditions of Delivery: Pickup is available or freight can be arranged for a flat rate of $25 anywhere in Aus.
hey mate. i'd be keen. gt3076r .82 internal gate ?
pm me if this is possible.
Unfortunatly these prices are for External Gate models only mate, as internal actuator models are more expensive..
fair enough mate. is there the option to pay a little more for the internal gate ?
cheers for the reply anyway
We have another Group Buy going for all the Internal Gate models, check it out here and see if your interested
http://www.skylinesaustralia.com/forums/Ga...al-t320157.html
whats the differences with internal and external gates? whats the advantages?
thanks heaps sorry i know it might be a silly question but i would love to know thanks!
In simple terms for you mate the Garrett GT30 Internal Range are run with internal actuators connected onto the turbo itself controlling your boost pressures, whereas the Garrett GT30 External Range need to run an External Wastegate setup which is used on your exhaust manifold..
is there any performance differences? between them?
Yes, External wastegates are commonly used for regulating boost levels more precisely than internal wastegates in high power applications. So it all really depends on your setup/application and what sort of power your looking for, how responsive/ top end power etc...
i can find someone to buy my 2860-5 setup ill be keen on a pair of the surge slotted 3076s but what is the smallest rear housing option u can get... is it .63 ?
lol how much power you looking to make??
just curious man, would also sound nuts
im interested, gt3076 0.86. anyone else put their name down?
Ill put your name down for 1 mate... We only need 4 more for this awsome price to go ahead :P
No worries mate, hopfully you can find someone to take the -5's off your hands then we will be up to 3 definates...
And yes 0.63 is the smallest rear housings you can go... Perfect for GTR setup.
hey bud... somewhere aroung 8-900awhp id like to try for 1000 with a FULL methanol tune..
and its a 3 litre aswell so two 3076s would be alright on the lag side... the current setup sees full boost (25psi) at 4200rpm in 3rd gear.. so i think maybe another 1000rpm to spool the 30series twins sounds reasonable..
  • 3 weeks later...
Any chance of getting the .78 divided housings with this deal... Or even for alittle more.?
Will chase this up and let you know what the extra charge is..
Unfortunatly Garrett dont have anything to suit the GT30 range in a split pulse 0.78 im sorry mate.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
