Hi,
Just a quick question.
Are the RB26 camshafts interchangeable between the R32-R33 and R34 models?
yes but with 34's you have to use the r32 33 cas spline when fitting the earlier cams. You can just use the earlier CAS and swap the cylinder and sync wire over when re-wiring the plug.
https://www.sau.com.au/forums/topic/320086-rb26-cams/#findComment-5225616
    • I've got a 2011 J50 that I imported six years ago. The unmodified factory AV system date and time has always been correct ( Japanese timezone of course ) up until last month. About two weeks ago, at engine start, the system wished me a happy new year ( in Japanese of course ). I can't think of anything that would make the system think that the date had changed, unless the GPS component has failed/reset somehow ? I checked the GPS reception in the system settings, and it can still see the satellites. Has any other J50 owner had this happen ?  It's no biggie, just annoying that it tells me the wrong date anytime I start the engine. 😅
    • Love following your adventures on IG, hopefully if you're still around in Japan when we visit again wouldn't mind going for a few beers with you (that's if you're keen on hearing how I hate Nissans).
