Due to a comedy of errors finally got my DR30 back on the road after nearly 9 months.
Fitted a new turbo and intercooler setup and took the car to a recommended workshop to have the Autronics unit fitted.
After the car being pushed out of the workshop every day for 3 months and sitting on a bush block with virtually nothing being done I took the car off them.
Another workshop took the project on and it took them 4 month to get the car running.
I've now spent 12 hours reassembling the car (why can't mechanics put covers etc back on when they're finished) and cleaning the car to get her back to where I had her.
What a relief that there is no long term damage to the paint after vitually sitting out in the sun for 3 months over summer.
On a more positive note the car drives great with 220rwhp which is a lot more than it had previously.
The tuner says the injectors are maxed out so changing them would net me a lot more power :banana:
I'll consider that but want to just enjoy the car for a while.
Missus thinks I have too many toys and wants me to sell to spend on and make room for my R33 GTR
3 cars and a Motorbike into a 2 1/2 car garage don't go :ermm:
https://www.sau.com.au/forums/topic/320823-dr30-back-finally/
OK thanks
One thing that was annoying me was that my car had a few pin dents in the rear guard and tops of the front guards.
Just got back from the dentmaster guy and I'm impressed!! Those guys are magicians.
Car looks fantastic
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
